andy and the r man
Noticed the back tire was nearly flat so I got home and put it up on the stand. Realized it was leaking around the bead and went to lower it down. Had a good grip on it, so I thought, but the surface was not quite level so the kickstand rolled back and over it went. I got a few scratches on the left fairing and a broken clutch lever. Not my day I guess.
Where should I buy a lever if I want to go with stock? I'm open to suggestions on aftermarket too, but nothing too far from normal looking.
Also, it is pretty easy to change out the lever? I imagine this is a fairly frequent occurrence.
