just a reminder, change out the winter time air in your tires to spring time air.
Already done and I flushed the blinker fluid also
I sure hope you used DOT6 Blinker Fluid otherwise your Brake light will not work when your right signal is on and your Headlight will flicker when your left Blinker is on.
what? serious? do the gas stations change the air in the tank to spring? I never knew this. Is there any harm in using the same air year round? Last time I put air in it was last summer. now that I think about my bike rode kinda funny last weekend..
do I need to check the muffler bearing in spring too or is it a winter project?
I'm replacing the rear tire tomorrow.
I was planning on re-using the air but maybe I should put in fresh air to be on the safe side.
DOT6, eh.
I was using DOT4 in the blinkers but I was concerned about it being corrosive.
Thats why I love the org. Always a source of good reliable maintenance tips.
You Guys Rock!
DOT6, eh.
You Guys Rock!
