gardian1701
ANOTHER MONTH, ANOTHER PROBLEM!
My starter gear wend pop! started her up the other morning and got a grinding spinning noise. Took her to the dealer, bad bad bad! if you liik on the 'pinned' article at the busa problem page titled 'A word to the wise' page 4 has a picture of exactly the broken bit.
Dealer says if it cant be welded I may need a new engine! My question is, does anyone know of the welding fix to work? I read on another forum of someone boring the hole deeper for the pin and using a longer pin! How long will a weld work for?
Im desperate! 4 grand could be down the pan!
Thank you.
Thank you.
