01LANDROCKET
Ok,my bike seems to run fine but it will stumble for a full minute before it starts.
I can put a full charge on the battery and it will start right up.
I can go ride it all day starting and stopping and it starts right up.
If I leave it sitting for 2 days it will still start but takes forever to bust off.
I think it is a problem with spark not fuel because you can smell the fuel.
I have measured the ohms in the stator and did a resistance check and all was well.
I measured the voltage coming out of the regulator/rectifier and it is on par with the suzuki tech book.
I disconnected the power commander for assurance.
I replaced the reg/rectifier.
I replaced the battery.
I have three bikes and I can start one right up, pull the battery that just started that bike and drop it in this one and it will just crank for a minute and then slowly start to fire???????? I can shut it off and it will fire right back up??????? If I leave it sit for a day it will fumble forever before starting again, maybe two days anyways.
Anyone got any more advice.
I undid the ground and emery clothed it and re-attached, and the ground going to the starter cylinoid. I also tested it.
