How's the compression?My motor does nothing but continuously turn over when trying to start. I have replaced spark plugs, coils, injectors, fuel filter, fuel pump, cold crank sensor, tilt sensor, stator, rectifier, new battery, and the ecu. I can't figure out why it won't start.
+1 - Just a no brainer: do you have proper (fresh) fuel in it?My motor does nothing but continuously turn over when trying to start. I have replaced spark plugs, coils, injectors, fuel filter, fuel pump, cold crank sensor, tilt sensor, stator, rectifier, new battery, and the ecu. I can't figure out why it won't start.
I sure do+1 - Just a no brainer: do you have proper (fresh) fuel in it?
I'll try thatcrank crank crank,,,,,,,,leave key on ,,,,,,,,check code?
It's an '04 with roughly 27,000 on it. It ran smooth when riding, then it started getting harder to crank it. Took a few tries at first for it to crank, then got to where it didn't crank anymore, it would do nothing but just keep turning over.Welcome along… how about giving up some info on history of the bike, usual stuff like year model, how long you’ve owned it, odometer reading, circumstances leading up to the no start situation.
You’ve thrown a lot of expensive parts at it and no result, it needs a diagnostic approach at fault finding.
Just explain what it was running like before this no go occurred.
Are you in a position to be able to competently work on the bike?It's an '04 with roughly 27,000 on it. It ran smooth when riding, then it started getting harder to crank it. Took a few tries at first for it to crank, then got to where it didn't crank anymore, it would do nothing but just keep turning over.
Check valve lash. It's possible you have none and some valves are not closing all the way.
