202mphbusa
Anyone have thoughts on the easyiest non messiest way to run the bike with my mechanical RCC scavenge pump removed? So I can mount a degree wheel and reverify my base timing setting?
Hi. Have you talked to Rick or Eric?Anyone have thoughts on the easyiest non messiest way to run the bike with my mechanical RCC scavenge pump removed? So I can mount a degree wheel and reverify my base timing setting?
Megasquirt MS 3.57What ECU are you running? Not sure why you need to remove the pump at all, just pull the plug. Do you have an adjustable timing light? When I verified my timing I set the FuelTech to 20° advance, set the timing light to 20°, pointed the light in that little hole and made the necessary adjustment in the ECU. Mine was off over 6°. Always a good idea to verify timing.
