Need advice on launching 1397 68 inch bike
badboysbailagnt
Give me some advice fellas on launchin my bike. Has 1397 220-230 hp 68 inch wheel base. Im also going to put nos on it before the end of the year maybe a 40 shot off the horn. Do you guys leave the line and work the clutch with 1 finger and hold on with your other fingers?
Do you hold the front brake slightly and drag the clutch to put some tension on the chain?
Im going to be using the stock clutch for a few passes before i get my lock up clutch also. Thanks alot fellas
MidnightBusainSD
Busa Rancher
I guess some suggestions would be to stage at 4-5000 Rpms possibly more it all depends on what you are comfortable with and then you will have to feather the clutch granted i would think at 68in wheelbase you shouldn;t really have any wheelie issues so you mabey able to let outta the clutch alot sooner, and i would just work the Rpms up from there but i'd get comfortable with what you got first before doing much more to it. Possible a clutch mod will help
badboysbailagnt
Yeah im just going to baby it at first untill i get the clutch mod,cusion and lock up clutch
GoldenChild
DID HE REALLY SAY THAT?
START SLOW AS IF IT WAS STOCK AND FIND THE SWEET SPOT...
rubbersidedown
TURBO-BUSA-RIDIN'-BASTID
maybe you'll get even more help in 1/4 mile
