Badbusa,check your front wheel balance,your front axle to make sure they are tighten to spec,check to make sure your steering head nut/bearing play is to spec, and try replacing your front fork oil with something better than what the factory uses,check your steering dampner.Hope one of these hints will help you out.Ride safe
