Ravenna
- Joined
- Apr 24, 2022
- Messages
- 8
- Reaction score
- 6
Ok this is my second attempt at rotating the internals as a whole. I have taken the inspection cover off and rotated the shaft a full 370 degrees and then it stops like its binding internally. I also dropped it into 5th gear and tried rotating the rear wheel at that point and I can't get past it. At the same time while it was in 5th I rotated the cam counter-clockwise and it turned the wheel back and forth. The engine is not hydro locked, nor does it have any visible damage or cracked block! Fresh oil was put in 5 months ago but, it hasn't ran in two years and has been kept nicely. I also removed fuel tank and checked the spark plugs but have not yet checked the injectors... Does anyone with engine experience have any ideas? The only thing I can possibly think of is a valve not seating properly and out of timing not letting it rotate properly? Idk I dont really want to remove the head much less the engine but, I at a loss other than sticking a scope down into it.
