ZVX cracks radially around the pins, untill the side plates explode-
Do your self a favor, throw away your stock sprockets, go with Tsubaki.
If you want to see how good your DID chain is do 5 or 10 2nd gear rolling burnouts from about 40mph. Stay close to home so you can push your bike back.
Once you snap a few teeth off the counter shaft sprocket the stock chain stretches like rubber- You might want to check yours.
ducmanic http://www.labusas.org/
6500 mles on this chain 132 passes busas likeem a little loose stocck sprockets in trash they have a high tensil strength i even had a non cush drive wheel for a while
