What is going on?
bajaboy169
??? What is going on???
My busa is running fine, top gear on the highway between 140 and 160 the FI starts flashing and I loose all power to the engine for about 1 maybe 2 seconds, the tack drops to zero then back up to about 4k. Then the power comes back and the FI still flashes. I pull over turn it off check the code it reads -coo nothing wrong! It fires right up and down the road I go until I hit 140-160 again what is going on? still no error code. Any idea's
05 with 6200 miles pc3 K&N air filter and straight pipe shorties with baffels.
Thanks for your time and thoughts
bajaboy
What year is your bike ???
What is the mileage ???
What mods have you done to it ???
Posted via Mobile Device
Yep, sounds fuel related. When you're asking for the bike to perform and use a lot of fuel, it doesnt. Check the filter, pump, but hopefully it's just a kink that makes shows itself when you get up there in demanding from the motor.
