I have a 2000 unlimited busa and the problem is that the dash / water temperature indicator does not indicate when the bike runs , only when it does check at start-up . i've changed the dash , the radiator temp sensor , the sensor from the engine that reads water ,the CDI , the fan does not start unless it's on direct contact . i took out the electrical harness and nothing seems wrong i check every connection i cleand with a spray the conntacts and still the same problem , Sorry for my english please help
