I'm getting a clacking noise when starting off. Can't tell if it's there at higher speeds though. Sounds like it's missing teeth or something. The engine sounds fine (reving it at neutral) but when taking off, it makes the noise.
It does need a new chain and I'll be doing both sprockets as well. The chain's out at almost the maximum adjustment. The clutch fluid is that dark gray color again and is at the bottom of the bubble rather than at the top so it needs to be changed again. 26,500 miles on the clock. I had the valves and throttle bodies checked before I left on the trip. Everything else is done pretty regularly.
Thoughts?
Carl
Thoughts?
Carl
