Hayabusa Owners Group
Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
SUSPENSION SETTINGS ?
OB_rchh
WHAT S EVERY BODY RUNNING, I KNOW IT S ALL PERSONEL BUT LIKE TO SEE HOW EVERYBODY SET THERE'S UP. OK 190LBS 5' 9'' FT PRE-LOAD 2.5 LINES SHOWING, REBOUND 2 CLICKS OUT, COMPRESSION 2 CLICKS OUT. REAR PRELOAD 2 BARS STIFFER. REBOUND 7 CLICKS OUT, COMPRESSION 5 CLICKS OUT.
Here are the #'s from the website above:
Suspension Settings
Front
Preload 2.5 lines showing
Compression Out 2 clicks Rebound Out 2 clicks
Rear
Preload 1.25inches of sag
Compression Out 5 clicks
Rebound Out 7 clicks
Hmmm, why 2.5 lines showing?? This would make it softer? the manual say change from stock setting - 5lines to 6 lines (stiffer)... I am 300lbs and ride hard... wonder what I should set everything at!?
These are the settings from 2wf.com in their Busa Test in 99. I tried lots of combinations but still like this one for 200 lbs of rider, sag will vary with your weight
Suspension Settings
Front
Rear
Bull dog
The fewer lines showing on the front preload the stiffer the forks will be. Clicks out on the rebound and compression means from full stiff,ie. clockwise all the way in is as stiff as it can get. Out say 2 clicks is a bit softer.
Top Bottom
