Can anyone give me a good starting point with my rear suspension. I've made the rookie mistake of chasing HP and not concentrating on suspension a little...Here's my setup-08 stage 2 busa, cut forks, 3.5 - 4 ins over, lowered front and rear about 2 ins, stiff shock link {makes the shock stiffer so I won't bottom out on the 08 tail}, 18-40 gearing, multi stage boost controller...
I assume I want my bike to squat fairly fast so I have the compression maxed at soft and spring soft also. Rebound is also soft in that I don't want the tire to unload. Am I all wrong here in my thinking? Also tire is a michelin pp race soft 190-50-17. I'M TIRED OF BLOWING THE TIRE OFF IN THE FIRST 4 GEARS IF I RUN BIG PROGRESSIVE BOOST. HELP!!!
Another turbo bike has called me out this weekend so some suggestions would be appreciated.
