Specs On Idle Speed.?
Discussion in 'All Motor' started by Machete81, Oct 27, 2016.
  1. Machete81
    Machete81 Registered
    Contests won:
    About how fast is the idle speed on a 06/with a 4 into one brocks exhaust and a power commander 5?
  2. Mike Chambers
    Mike Chambers Registered
    Contests won:
    Idle speed usually is around 1100 rpm, but if I doubt check with your Suzuki mechanic
  3. twotonevert
    twotonevert Member of P.E.A. Moderator Donating Member Registered
    Contests won:
    Name:
    James Wilson
    1250 per the book if i remember right, it is the same on GenII
  4. Machete81
    Contests won:
    Thanks fella's another quick question tho this has nothing to do with idle speed tho, when i change my oil, if i ran semi synth, and am now going to full synthetic should i change my filter or is that not going to matter.?
  5. Machete81
    Contests won:
    I have barely put a 1k miles between oilchanges.
  6. nosbig
    nosbig Registered
    Contests won:
    Name:
    Shawn
    It's 13 dollars. Just put a new filter on it. No you don't HAVE to but why not.
    piratediverjefff likes this.
  7. Machete81
    Contests won:
    I came to that conclusion my self.
  8. Johnnycheese
    Johnnycheese Registered
    Contests won:
    Name:
    Johnny Cheese
    Like I have said many times changing your oil without a filter is like pissing with your pants on
    piratediverjefff and nosbig like this.
Share This Page
