Ok, so looking around I hear of ppl using a .090" thick spacer b/w the case and cylinders. I understand this lowers compression, however... Doesn't adding the spacer increase the quench so much, .090", that it would leave the engine severly prone to detonation?
In the car engine building world I come from, and my experience with SBC, and recently LSx engines a tighter quench height is preferred to quell detonation. I built my Camaro with a quench height of only .035".
For those wondering, quench height is the distance from the top of the piston in TDC to the cylinder head... depending on if the piston is out of the hole (+) or in the hole (-) deck height, the thickness of the head gasket. In auto applications, having a quench of less than .045" is preferred and dramatically helps FI cars run boost with less chance of detonation. On top of this, it of course adds a miniscule amount of hp, but mostly its set to keep the engine from grenading. Of course you can run more aggressive timing with a tighter quench height as well, so there are many advantages. Only disadvantage is if using rods that stretch easily, weaker rod bolts, etc.. that when cold, before the operational expansion is finalized you can smack pistons with valves...again, not an issue if your using say Aluminum block, heads and quality rods and bolts. But who really romps on their stuff when cold anyway, thats just careless.
I am thinking a nice stock bore, maybe slight stroke, using new rods, bolts, dished pistons, and the turbo in the end. However, until then, thinking add turbo, and save for the engine build. Just looking for experienced users of or against the spacer issue to lower compression. Yes I know its not needed, just keep the boost lower, but I also know boost (or any power adder) is addictive.
Thanks for the reading time.
Charlie
Charlie
