ndhaley
Hello fellas,
I have a 2000 Turbo Busa. It runs and drives fine but...
When it is stopped and I pull in the clutch when it is already in 1st gear it correctly disengages the gear however let say I pull into my driveway in 1st and pull the clutch in. And with the clutch still depressed I begin to back it into the garage I hear a rubbing noise coming from the right side of the bike and it acts like the clutch is still partially engaged... But only while going backwards. Now I would normally say that my clutch cable just needs to be adjusted but the noise is on the other side of the bike than where the shiffter and transmission are. I know it's something simple. The sound is like something is touching the right hand side cover on the inside of the cover. Can anyone shed some light on this? Please post. :-)
<!--EDIT|ndhaley
Reason for Edit: None given...|1111174952 -->
<!--EDIT|ndhaley
