Yup.Yeah...it will run like crap. The bike is tuned for 90-93 octane fuel, if you put a RACE engine in it that was tuned for 110...then it would run good.
He posted in the '08 forum...I think he has a Gen2 and they need 90 min. You should not run 87 in a Gen2 BusaYup.Yeah...it will run like crap. The bike is tuned for 90-93 octane fuel, if you put a RACE engine in it that was tuned for 110...then it would run good.
In fact you will actually go faster with 87 octane. You want to run as low an octane rating as you can without detonation. To run 100 or more you would have to advance the ignition to compensate for such a slow burn. Probably the best fuel at the track or the dyno is MR9 at 87 ocatane, and if your are mapped for it is good for an extra ~10 HP. MRX01 is good as well at 90 octane. Both are expensive and tough to get. I would recomend good old 87 pump gas.
hmm could be but this is really common in AZ in places.. Parker Strip or other waterways where we ran blown gas or other hi perf motors all the time had Sunoco/Torco racing fuels along with Methanol all the time...Even if you're running a turbo or hi-compression motor and need 110 octane fuel, I'd be very wary of running any fuel pumped from a tank at a gas station.
Cam 2 purple worked REAL good in the circle track car $18 for 5 gal. back in 92[115 octane].Switched to VP racing fuels [108 octane]it was only 2 bucks a gal then.That engine run like crap with 93.hmm could be but this is really common in AZ in places.. Parker Strip or other waterways where we ran blown gas or other hi perf motors all the time had Sunoco/Torco racing fuels along with Methanol all the time...Even if you're running a turbo or hi-compression motor and need 110 octane fuel, I'd be very wary of running any fuel pumped from a tank at a gas station.
We ran 100 LL octane AvGas pretty regular too without any problems.. AvGas is "highly volatile" however (evaporates very fast) and so can present some vapor issues. Some debates over the use of avgas but the composition is not the different from regular gas (except it had one very important additive "lead")
you can absolutely see ET differences in fuelsTimeslips and dyno pulls don't lie. 87 makes more power than 90 or 93 on the GenII. Period. Oxygenated fuels make even more. A good cylinder head design with high compression will generally not detonate on lower octane.
You know what I'm talking about,roll a cylinder to TDC and the dome sticks up much higher than the block........
our compression wasn't that high,after all it was the stock class.....Cam 2 purple worked REAL good in the circle track car $18 for 5 gal. back in 92[115 octane].Switched to VP racing fuels [108 octane]it was only 2 bucks a gal then.That engine run like crap with 93.hmm could be but this is really common in AZ in places.. Parker Strip or other waterways where we ran blown gas or other hi perf motors all the time had Sunoco/Torco racing fuels along with Methanol all the time...Even if you're running a turbo or hi-compression motor and need 110 octane fuel, I'd be very wary of running any fuel pumped from a tank at a gas station.
You know what I'm talking about,roll a cylinder to TDC and the dome sticks up much higher than the block........think I know the pistons you are talking about ...our blower motors were mostly flat top or dished however... now you wanna see one of our alky motor pistons? This is similar (we had the wrist pin lowered by .100)and then fly cut the valve pockets another .125" effective ration was 15.5 to 1
WOW....... i think thats the smoothest A/F #'s i seen yet on these bikesI'm at 13.2:1 compression.
We mapped my bike with Sunoco 260 GT Plus Unleaded racing fuel. It has 5% oxygen content, 99 Motor octane, 109 Research octane, 104 R+M/2. It made .5 hp more at peak and in places 2-4 hp more with 91 octane pump gas and almost exactly the same A/F. I run the race gas for the extra assurance against detonation and run the 260+ at the track.
Leave the 110 alone in a stock compression bike. If you want more power on the dyno or track tune it with MR9. It is some nasty stuff, don't leave it in the bike.
Sunoco 260 GT Plus
