Every bike is different, as are exhausts and base maps. Ballpark Guesstimate with a base map, 5 or 6 hp, 0 to 2 ft lbs trq. If you have your bike dyno tuned(by a tuner that knows what they're doing) 10hp, 4 to 6 ft lbs of trq, maybe a little less or more(as I said Guesstimate). With the dyno tune though you will have a noticeably smoother running bike with no flat spots in the power and much improved throttle response. Well worth the money.
Check out the Ecu Editor, cheaper and far superior to a power Commander. All a pc can do is map fuel(some models map ignition and you don't need that)the Ecu Editor can remove the top speed restriction, turn your fans on sooner, turn off your pair valve, and anything else that the computer controls. boostbysmith.com - Home
