heavyjeffd
Just curious if anyone is running the Power Commander LCD with the PCIIIr and what your thoughts are.
Thanks.
Thanks.
If you could use a pcIIIr i would have gottin one by now... could be wrong but think your wright.Guys Help me out here. I thought the LCD unit connected to the unit by USB. I also thought only the PCIIIusb had an USB interface.
I would call their tech support before I banked on it. For instance one of the functions allows you to swap maps. You would need to communicate to the Power commander on a data busa to do that.According to the Power Commander website you can use it with the PCIIIr. The USB interface was just for programming/setup, it has it's own interface (I think) to connect it to the PCIIIr.
Any closer pics of the stem mount? It looks really nice, I'd love to see some detail.
Thanks.
According to the Power Commander website it uses a 'quick disconnect cable', in the picture it's a white-plugged cable as mentioned above.I would call their tech support before I banked on it. For instance one of the functions allows you to swap maps. You would need to communicate to the Power commander on a data busa to do that.According to the Power Commander website you can use it with the PCIIIr. The USB interface was just for programming/setup, it has it's own interface (I think) to connect it to the PCIIIr.
Thanks.
I could be wrong.... that is the reason I'm asking.
Ooops...I meant raffle.Seems like a great AUCTION for the .oRg!!
