Charlie Brown
Probably been discussed before but couldnt find anything ... but I was wondering if ..
You could use a power commander and instead of running the TPS wire to the throttle position sensor, you could maybe instead attach this wire to say a MAP sensor on the intake manifold. My thoughts are that instead of throttle position points on the side of the map, they could be treated as boost reference points?
So if you where at a steady 10% throttle and you came to an incline, and the bike started to build boost, the map sensor would adjust accordingly?
Thoughts?
Pros Cons?
cheers
Thoughts?
Pros Cons?
cheers
