Oil Preference
hayabusa_83
obviously, according the manual suzuki recommends 10W-40 oil.
me being the non-observant guy i am threw in some 10W-30 on accident. at first i freaked but eventually realized it didnt make a difference. so question: ITS ABOUT THAT TIME AGAIN, AND I WANNA TRY SOMETHING NEW. WHAT'D YA RECOMMEND? WEIGHT? TYPE? HOW IS IT? ETC! (i'm using Valvoline SuperSyn now)
thanks,
Brian~
I use Motorex oil .. oem filter. good stuff.. local dealer is the distributer for this oil..they said its the best around so and ive been using it in all my bikes.
mobil 15-50 red cap. slightly hard to find in these parts now that they changed the makeup of it.
The oil that replaced it , the Extended Performance 15w-50 is made of the exact same base oils but with more zinc as a primary anti-wear additive, secondary anti-oxident .
Simply put , the EP 15w-50 is a better version of the old red cap oil with around 300 ppm more zinc and phosforus .
New oil analysis of the Mobil EP 15w-50
Moly 78
Boron 290
Calcium 2951
Magnesium 18
Phosforus 1230
Zinc 1381
VI @ 100c  18.0
Old Red cap 15w-50
Moly 210
Boron 130
Calcium 2540
Magnesium 11
Phosforus 840
Zinc 930
VI @ 100c  17.8
Motorex 5w-40
Boron 610
Calcium 2680
Magnesium 20
Phosforus 998
Zinc 1110
VI @ 100c  14.6
It's apparent to me that the EP 15w-50 is using a different type MoDTC " moly " . Probably the same type used in the Mobil race oil . They need less of it to use as an anti-oxident because the EP oil uses more zinc in which once again is an anti-wear additive primarily and a good anti-oxident secondary .
Boron and Overbased Calcium also serves as secondary anti-wear additives .
It's good oil for the money and better than "some" of the ultra expensive bike oils IMO .
More current oils .
Amsoil 10w-40
Calcium 4299
Magnesium 10
Phosforus 905
Zinc 1039
Mobil Bike Oil
Moly 88
Boron 261
Calcium 2653
Magnesium 15
Phosforus 1698
Zinc 1831
Belray EXS
Mag 24
Calcium 2899
Phos 896
Zinc 1080
Castrol R4 Superbike Oil
Mag 6
Calcium 2401
Phos 948
Zinc 1050
Repsol 10w-50
Boron 171
Calcium 560
Magnesium 1000
Phos 900
Zinc 1119
Synergyn 15w-50 = groovy 5 buck per quart oil
Moly 110
Boron 111
Magnesium 8
Calcium 2860
Phosphorus 1143
Zinc 1290
Motul E-Tech 100 10w-40 = same as Kawasaki Synthetic
Moly 85
Magnesium 461
Calcium 2153
Phosphorus 1187
Zinc 1321
I have the ultra studly Maxima oil analysis here somewhere that I'll post later .
<!--EDIT|mountainmotor
Reason for Edit: "To add new oil anaylsis's"|1117757420 -->
Is this "red cap" or "gold cap" oil made for motorcycles? I was always told to use a motorcycle specific oil because of the clutch. Is this the red cap and gold cap oil found at wal-mart?
perhaps a stupid question, but just how does one decide which is a "better oil" based on the composite breakdown? Do bikes have specific composit needs vs. cars?
Castrol GPS semi-synthetic and an OEM filter. Stock weight. It will make your Busa shift smoother than silk
