Hey i just finished cleaing the mold off my bike and i installed a BDE full system One of the header pipes touches the oil cooler is that cool? Its tounching the metal part. I tried bending the oil cooler line but that was a no go
the heartache and pain will be worth it!!!!So im supposed to replace the bracket holding it on. With the washer do i just put a larger garmount there?
This is very good advice!!!DO NOT leave the oil cooler line touching the header. It will eventually rub a hole in the oil line.
put a channel lock plier on the line and you can twist it away from the oil cooler. all it needs is a 1/32- 1/16th of an inch.
