05 Hayabusa. Was out for a ride when my bike started bogging down. After a few minutes the engine shut off. When I turned the key I could not hear the pump priming so I got a tow home. I pulled out my multimeter and tested everywhere dealing with the pump. I’m not getting power at the pump harness or the fuel pump relay. I’ve tried new fuses and and new pump relay. I also tried my buddy’s 2007 ecu, ignition switch, tip over sensor as well as bypassing the kickstand sensor. At this point I’ve exhausted all my knowledge so any insight is appreciated!
