Berlin Germany
How on earth can a gen 3 make that much torque over any other tuned generation of Hayabusa?if u got the gen3-ecu flashed this way - see jpg/pdf in the appendix
soooooooooooo much more Nm at lower rpm than usual
the red line tells the factory values
the blue line is the flash
There has to be some serious engine work done to it for it to make those Hp and Tq figures
Even Moore Mafia that probably flashes and tunes a couple hundred Hayabusas of all generations isn't able to make those figures without a pile of work and even then isn't making anywhere near those torque values.
I see two problems here.if u got the gen3-ecu flashed this way - see jpg/pdf in the appendix
Man??if u got the gen3-ecu flashed this way - see jpg/pdf in the appendix
no bee - the engine itself is still in original shape - nothing done at the hardware.There has to be some serious engine work done to it for it to make those Hp and Tq figures
There must be some magic going on to get anywhere close to those torque numbers.....no bee - the engine itself is still in original shape - nothing done at the hardware.
If you are referring to the Gen 3 Moore Mafia did it's a pretty average gain for a bolt on modified Hayabusa......That's only 113 ft/lbs that isn't a big gain
Frank is in Europe, they talk a different language 90Nm at almost idling RPM, that is 66.28 ft-lb at around 1,600RPM, these bikes idle around 1300RPMThat's only 113 ft/lbs that isn't a big gain
read my pdf and ? .wait, what ? starting torque at nearly 100nm????????
I am getting really excited if this is actually happening. that is an enormous gain. My god.....read my pdf and ? .
yes the values are taken by a yearly calibrated "ackermann" test bench
and i know "jan stecher" personally - so i know i can trust him and his job.
ask @Kojak - he got exactly the same map on his gen3´s ecu and he is overwhelmed by the power/ the behavior his gen3 have.
the only prob/issue , a flasher will have - (i don´t know what exactly) a suzuki-shop has to do something with their softwrae to the gen3 that it will run the values of the pdf above.
It must be "Element 115" used in he pistons and sleeves from reverse enginered Alien Technology
