Lucky34
I was wondering what you guys recommend when it comes to nitrous. What is EVERYTHING you need to put nitrous on a stock busa... One of the scenarios I'm looking at right now would be something like A&J's kit with the controller box. $400 for the nitrous kit, $400 for the controlelr box, and that's it. Right? No need for a PCIII or any other crap? Get a switch to enable the nitrous and when at 100% throttle on a specified gear it sprays...
The other scenario is getting just the kit (either from A&J, or any other nitrous kit out there), hooking it up, and having a switch to arm the nitrous, and then, lets say, use the horn button to spray the nitrous. However, wouldn't I need a special fuel map for this? To avoid running lean and blowing something? If I was gonna go with something like this, What would I need besides just the nitrous kit? Would I need to get a PCIII and get a special map to run with nitrous?
What setup do you guys recommend? Any info appreciated...
** Also, what are the differences between the dry/wet systems? I'm looking for a max gain of 60 horses, so I "think" a dry kit would be better... wouldn't it? it seems like the wet kits are a lot more hassle **
<!--EDIT|Busaman86
Reason for Edit: None given...|1124527320 -->
<!--EDIT|Busaman86
