HMan
Ok, here is the deal. Went and had a new front tire mounted on Saturday. Was on my way home racing a storm.
I have a rough mount accessory plug for my GPS. In my haste to wire this up, I did not mount an inline fuse.
While I was getting the tire mounted, I put a new air filter in. When I put the tank back down I positioned the wires for the GPS wrong and pinched them. On the way home my tank rubbed through the wire's insulation and it grounded out on the outer rim of said tank. I didn't know this immediatly though. All I knew was that I suddenly went dead in the water. I coasted to the side of the road and tried to start it back up.
The bike turned over fine but it wouldn't start. Whenever I'd crank the throttle it would change tone in the exhause but it still wouldn't fire. I did notice that in the clock it said "FI". So, after a bit of thinking, I found the wire touching the tank. Amazingly it wasn't all melted and on fire as it was still touching the tank and it was still un-fused.
I immediatly hauled out the tools and got the tank up and moved the wire. I had called my Dad and he was enroute with a trailer. When he got there I tried to start it again. It actually got a moment of fire and just did a low growl for a few pulses and then just cranked again.
Loaded it up on the trailer and tried it again. Same deal. It growled and that was it. Its been that way since.
Once home, I tried spraying some starter fluid in the air box and the motor will fire just enough to growl so I figured it was getting fire. Still at a loss.
THEN, I realized something. When I turn the key, there is no sound of the fuel pump priming. Thought I'd check the fuses. Just came back in and I can't see a single fuse that is blown.
So... idea? Suggestions? I really don't want to spend a fortune to get this resolved and quite frankly I don't have a fortune to spend.
Any ideas you can give would be helpful.
