Will they be very bright?(heavybusa @ Mar. 25 2007,17:27) Looks like an 1157 push and turn (dual filament) just like stock
What lens goes over them? Should be as bright as stock unless you upgrade to a brighter bulb.(Shanling @ Mar. 25 2007,22:28)Will they be very bright?(heavybusa @ Mar. 25 2007,17:27) Looks like an 1157 push and turn (dual filament) just like stock
Does this thing have two sets of turn signals? One intermingled with the brak and the other stand alones that are further in the back?(heavybusa @ Mar. 25 2007,17:29) Looks like the brake lights are already wired into that white plug and you need to match power and ground for the turn signals.
I'd use tape and label the right and left.
It has clear lenses for them.(heavybusa @ Mar. 25 2007,17:30)What lens goes over them? Should be as bright as stock unless you upgrade to a brighter bulb.(Shanling @ Mar. 25 2007,22:28)Will they be very bright?(heavybusa @ Mar. 25 2007,17:27) Looks like an 1157 push and turn (dual filament) just like stock
So I do not have that undertail, I am just trying to help you with the wiring.(Shanling @ Mar. 25 2007,22:31)Does this thing have two sets of turn signals? One intermingled with the brak and the other stand alones that are further in the back?(heavybusa @ Mar. 25 2007,17) Looks like the brake lights are already wired into that white plug and you need to match power and ground for the turn signals.
That pic is a smoked lens, plenty bright for me.(Shanling @ Mar. 25 2007,22:32)It has clear lenses for them.(heavybusa @ Mar. 25 2007,17:30)What lens goes over them? Should be as bright as stock unless you upgrade to a brighter bulb.(Shanling @ Mar. 25 2007,22:28)Will they be very bright?(heavybusa @ Mar. 25 2007,17:27) Looks like an 1157 push and turn (dual filament) just like stock
In that diagram, you do not have to use all 4 turns.(Shanling @ Mar. 25 2007,22:47) The picture with the diagram is perfect!!! Thank you so much!!
Hey thanks for that post!!(thebbbusa @ Mar. 26 2007,17:18) I didn't read all the way through this but I can tell you a few things. The undertail you have is just like mine. I was told to NOT use regular bulbs in the tail because the plastic bulb housing will melt. You will need to use some type of LED bulb that will fit under the lens that came with the undertail. The regular light that comes with the undertail is not very bright during the day. You can purchase 48 LED bulbs now that will fit in there. I still haven't done that, but I did replace my turn signal bulbs with a different model. Now they are really bright.
I used some of these, which are very close to the size of the stock signal lens.
Found them at JP Cycles Click Here
I'm sure you can see a difference in the cheesy LED signals shown side by side with these:
<embed width="430" height="389" type="application/x-shockwave-flash" wmode="transparent" src="http://s110.photobucket.com/player.swf?file=http://vid110.photobucket.com/albums/n116/thebbbrain/VCLP0044.flv"></embed>
The wiring is the same. I kept the little ones up by the tail lights, but you really can't see them. And with these signals, I didn't need the load equalizer or special flasher.
Eventually I plan to get the 48LED bulbs for the tailight/brake light, but at least right now you can see where I am thinking about going.
Sportbikeeffects.com, a Mototeck distributor carries the 48 LED lights, but they aren't cheap.
Click here to see them at Sportbikeeffects.com
Good luck.
