Bought an 04 couple weeks ago. It had a full yosh exhaust, but no power commander. I installed a TRE first, some said it might help. I then purchased a PCIII USB, loaded map from dynojet for the full yosh exhaust. Still no help with the low RPM miss. It seems toline out about 2500 rpm and run like a stripped ape after 2500 rpm.
I did look at the map and it does nothing, has zero's in the lower rpm's. I put in 15% more fuel on anything under 2500 RPM's. It runs a whole lot better however, I think I'm just putting a bandaid on an original problem.
I've sync the throttle bodies,checked the clamps on the throttle bodies.
Could it be a bad sensor?theidle is all over the place, erratic as can be.
Thanks, buffy
Thanks, buffy
