Just posted on Motorheads site...I don't need the H beams will never have that sort of HP...Good looking out...Schnitz has everything I need may just order bulk from there...
My buddy ordered his set from there as well... Nothing wrong with that, but....
I will tell ya one thing....
If you are going super power...
You are going to need head gasket, block spacer, and head bolts... You may already have the gasket and spacer, but you will need head bolts... Best ones on the market are MOTORHEAD's head bolts... You will have to drill out the case, block, and head for the bigger bolts and the head gasket holes will probably be a little small after your done and require a little bit of dremel work... (I assume you are already running a good head gasket...
) If you order from MOTORHEAD, he can setup a configuration for you and I bet he would give you a deal on the combo... He also sends his head gaskets pre-drilled for the bigger head bolts...
