justin726
I bought the 5000K kit form XenonKing about 2 months ago. I installed the kit and for the first few weeks everything worked great. Then once in a while I noticed that after I started the bike up the HID would be off. I had to turn the key off, turn it back on, and refire the bike and the light would stay on. This problem started to happen more and more. The light would come on with the key, but then flicker a little durring the starting proces and then shut off before the engine was started.
I emailed XenonKing and he said I was going to need a wiring harness which looks to be about $28 bucks. Well, now here lately, the HID won't stay lit through the starting process AT ALL. I went for a ride yesterday and the only time the HID was on was between the time I turned the key on and before the bike was running. It didn't stay lit once. Sounds like my problem is getting worse. I'm not sure if a harness will solve the problem. I'm just curious to see if anyone else has run into the problem of having a bulb tha never fires. I've seen a few similar threads about flickering bulbs, but not quite like this. I'm going to be emailing XenonKing here shortly to see what he says to. I like this bulb soo much, I really want it working.
