Most of the guys I ride with have R1s, does anyone have information on kits for them. They have two low and two high beams, mounting suggestions, etc. All input appreciated. You might say my newly aquired HIDs have wow'd them.
I definitely WOULD NOT go that route!. The look of the wire tells me that this isn't something you'd want to use Radio Shack butt connectors on.(guido4512 @ Mar. 07 2007,12:12) Can the wire be cut and spliced to lengthen so you can mount the ballast in the rear?
The power for the ballast would be alright but the power to the lights has a special cable. I might contact the manufacturer and get a special order if it was that important.(Juggler @ Mar. 07 2007,16:06)I definitely WOULD NOT go that route!. The look of the wire tells me that this isn't something you'd want to use Radio Shack butt connectors on.(guido4512 @ Mar. 07 2007,12:12) Can the wire be cut and spliced to lengthen so you can mount the ballast in the rear?
...And I use them on EVERY wiring project.
