ok guys...real simple stuff.
If the pics are in your Comp, there are two ways to post your pics:
Method # 1
Scroll to the bottom of this page. See that white box on the bottom? The one with all the smilies at the bottom of it? Look at the gray border on top of said white box. Now look to the left. See that button? The one that says "Browse..."?
Click that button. It'll open up a new window with a folder selection. Simply open the desired folder and then click on the desired pic. Hit "open" on that smaller window and voila....you have your pic. Type in your post in the white box and hit the "Quick Post" button. You're done.
The pic, however, must be less than 200kb in size. You can find out the size by right-clicking on the pic and going to "Properties". Look for "File Size". It'll show you there. Edit accordingly.
Method # 2
After the last post, you'll see a gray border. Underneath this border you'll see three options: "Add Reply" , "New Topic" , and "New Poll".
Click on "Add Reply". Refer to the picture if you're gettin a little lost.
You'll now be taken to a new page. The attached picture shows a part of what you should be seeing.
Click the button denoted by the red circle. A small window will open up with a folder or destination selection. Click on the folder, then double-click on the pic. It is now attached. Type in your post, click the "Post" button and you're done.
Again, be sure that the file is NO LARGER than 200kb.
IF THE FILE IS ON YOUR WEBSITE:
Click on the "Add Reply" Button at the bottom of the page. Click the button denoted by the purple circle. It'll bring up a window asking for the http address.
Put in the http address, click "Ok" and then type your reply. Hit the "Post" button. You're done.
