hi guys can you please help? just installed new chain and both sprockets. bike is up on stands. turn engine on and put in first gear the wheel spins but every few seconds the chain hops. sounds like the engine is choking. but when i throttle it to about 3000 rpm it all runs smooth. can i be having an clutch or gearing problem? also the bike runs smooth in neutral at idle. but there is a little clanking noise that comes from the front sprocket area when it is in gear thats when the hop occurs. any info would be greatly appreciated. thanks
