Blaze
I was surfing around and found this gear speed calculator. You can change various numbers (Wheel Circumference, Engine Speed, Front Sprocket, Rear Sprocket, etc) and see how it affects your speed in each of the six gears. The default mode is set for a stock busa.
I think this is very cool and wanted to share it with you. Some of you may already have this information in some form or another. If you don't here it is.
