celticBandit
I noticed that my front end was a bit vague in fast corners lately and there is a metallic rattle/clinking over hard bumps from my front end. So I jacked up the front end to check wheel bearings and steering head bearings. Both OK.
But I am getting a clicking noise from my right hand fork. There feels like a little movement in it when I pull/push the forks to me and away from me. It feels like the ticking noise is coming from inside the outer tube were the oil seal is located, but there is no oil leaking from the fork seal. I think it may be one of two things:
1. Preload adjusted rod has come loose inside the fork.
2. Bushes are worn and I need a new fork
I was just wondering if anyone had seen this before and has anyone any other possible solutions?
Thanks
Tony
Thanks
Tony
