FI light after installing full system
Bubba Zanetti
Hi,
I've read lots of threads on here about adding an oxy sensor to US bikes, mines a Euro model (Ireland) and I've put a full Yoshi 4-2-1 system on with no bung for inserting the o2 sensor. I've no desire to go drilling the exhaust and adding the sensor as I'm sure if it was that critical Yoshi would have done that already.
How can I get the FI light to go out when I pkug out the sensor? I read somewhere that you can short out 2 of the 4 connectors with a 330 ohm resistor, but which 2?
GEN 1, 2006 btw
Cheers.
Brock's makes a dummie plug for the O2 sensor if you haven't already found one.
Ok, so when I eventually figured that the reason I couldn't find any info on the sensor in the manual was that it was a US manual, downloaded the right manual.
To check the correct operation of the sensor it should read 5.6Ω across the bottom 2 pins, the white wires. 34c at the local shop and job done, no more FI light.
