D Dnyce Registered Jan 9, 2023 #1 Any of you guys that don’t use the check valve have starting issues?
D Dnyce Registered Jan 9, 2023 #3 Oh good. The hole is so much bigger without that check valve, I didnt want to use it
michael parris heuberger Registered Jan 9, 2023 #4 202mphbusa said: no check valve no starting issues Pump is down under swing arm Click to expand... Hi. You are still using an electric pump?
202mphbusa Registered Jan 10, 2023 #5 michael parris heuberger said: Hi. You are still using an electric pump? Click to expand... yes
