Went to start my 07 yesterday, turned on the ignition, engine cut of to on, pressed starter, got about one second of what a normal start up would sound like then nothing. Like there was no battery connected at all. Strange because it was running fine two days prior. Tried to jump it and got the panel to light up and the starter to turn a little but not enough to kick it over. Called for a tow and the AAA guy have a portable jumper, hooked it up and got it to start but it died as soon as the lead from the jumper was removed. A couple times while turning the ignition on and off I got the panel to light up but it would die as soon as I turned the engine cut off switch to "on".
Any ideas?
Any ideas?
