Versicarius
Installed 4cm dropped footpegs and had to lower the gear shifter and rear brake lever accordingly. However, the gear shifter is at the lowest point it can go (any further and you can't downshift because it hits the kickstand) and it still feels like it needs to go a bit lower to be comfortable with the lowered pegs. Does anyone have any ideas for a potential solution to this? I've seen someone who bent their shift lever outwards to avoid the kickstand, and also someone who bent their kickstand in, but I'd rather avoid having to do that. It looks like something that would be solved just by having the shifter be a few centimetres outwards but I've not seen a method to do that successfully.
