clutch basket set up
fizzer
hi folks,just a quick question please if anyone has the answer,i have taken the hole clutch basket out to replace gear position sensor,it had a mind of its own,anyway before the plates go back in there is two washers,a large flat one, and one with a taper on it,am i corect in thinking the the flat one goes in first then the tapered one pointing inwards,followed by the first plate which is a smaller plate than the rest of them.
i should have taken more notice when i took it apart.
thanks guys
thanks very much ryc1966,the picures on that were far better than the ron ayers i have used before,thanks again.
ian
...flat one goes in first then the tapered one pointing inwards,followed by the first plate which is a smaller plate...
Yup, you're right, except the "pointing". It should be outwards, I think.
Bye
D1
after downloading the manual,i can confirm,that the conical washer does point inwards,its all in the manual,just in case anyone else is reading this thread for there own use.
