For you AR fans:
I invite your attention to this thread on another forum:
Improved AR15A2/A3/A4 & AR15 Carbine Zero Targets - 50/200M, 100M, & 300M Zeroes - M4Carbine.net Forums
A member created a .pdf file of zero targets that will allow for a 100M zero on a 25M range, using ballistic data for M193 and M855 ammunition for either iron sights, EoTech or Aimpoint optics. I measured out 25M (82.081 ft). and shot the EoTech targets supported (out the back of my carpeted pickup bed with my rifle bag as support) for two Eotech-equipped rifles (one with a G33 magnifier). I started with the top left target, and eventually confirmed with the bottom left target.
After getting a zero I liked, I shot a standard 25yrd pistol target at approximately 100 meters. Pics are below. Except for a little bit of trigger control, not too dang shabby for an amateur. At 100M, the black part of the pistol target IS the red dot. I liked the contrasting color silhouette (yellow or green) better than the black or red ones easier to see against the red dot. I am very pleased with the results. What I really like is I can print these targets with my PC printer any time I want.
P.S. a Geissele SSA trigger is head and shoulders a better trigger than a MILSPEC trigger....HIGHLY Recommend. G33 Magnifier ROCKS.
All the .pdf files are below attached, for several different ranges using different optics. Files contain different color silhouettes...
