Not a direct swap...
The Rotor and maybe the pickup.
There is also a possibility of the injectors/harness but I don't remember if they chnaged in 01or 02.
The ECU is a 16 bit on the 99-01 models. This changed the rotor/pick up requirements when the ECU was updated to 32 bit in 02.
If you are making the swap, you should have everything you need regardless.
