Due to such success last year, we decided to offer it up again this year. From now until the end of March, BOOSTED CYCLE PERFORMANCE is offering up $50 ecu reflashes!
What does it do?
-Gives you MORE POWER by increasing ignition timing in gears 1-4.
-Removes the 186mph speed limiter.
-Allows you to remove a TRE if you installed one. (Which is robbing power anyways)
-Shut off O2 sensor, and pair valve FI lights. (Gen 2)
Upon request
-Raise rev limiter.
-Configure ecu shift kill for air shifters.
-Configure ecu controlled shift light.
This does not effect your current tune, nor does it require you to retune your bike. This offer is good for all Hayabusas from 02 and up. You are responsible for covering the return shipping.
What does it do?
Upon request
-Raise rev limiter.
