Results 1 to 18 of 18
  1. #1
    Rookie nitro71455's Avatar
    Join Date
    Aug 2010
    Location
    Utah
    Posts
    156
    Default Escort Passport 9500ix mounting
    From what I can gather, there seems to be quite a few of you guys running these. I got mine today and I'm trying to decide how I should mount it. I may velcro it to my Moto-D mount I use with my Iphone. I'd like to see how some of you guys did yours as well.
    I'm also wondering how well the radar works from behind since our bodies kind of block the pickup for it...
    Thanks All!
  2. #2
    wannabe HOON
    kromdom's Avatar
    Join Date
    Feb 2006
    Location
    SoCal
    Posts
    5,757
    Default Re: Escort Passport 9500ix mounting
    Your body will/should/could NOT interfere with it. As you may have already done so, it works just fine inside your car where the detector is surrounded by hunks of metal/plastic, etc.......much thicker/denser than our bodies
  3. #3
    Professional Pilot Mr Droo's Avatar
    Join Date
    Mar 2009
    Location
    Cleveland
    Posts
    622
    I made a bracket to fit between my right mirror and 1" mirror extender. I ran the audio cord and the power cord to the right side through the upper dash panel. BTW, if you're going to use an audio cord to a set of ear buds or helmet speakers... YOU MUST USE A MONO INPUT ON THE 9500ix!!!!! I can't stress this enough!!!!! When the right and left side of a stereo input are pushed into the 9500ix and power is turned on... the right and left channels merge together and will overdrive the audio chip! It'll immediately fry! I unknowingly did this and Escort DID repair it under warranty (as they unintentionally omitted any literature warning end-users about using stereo inputs instead of mono inputs with these units).
    I've not had any issues receiving Ka, K, or Lidar
    I'm at work right now and don't have access to any decent closeup pictures, but I'm headed out to Cedar Point this afternoon and will take a few pics of my setup if you want.
  4. #4
    wannabe HOON
    kromdom's Avatar
    Join Date
    Feb 2006
    Location
    SoCal
    Posts
    5,757
    Mr. Droo, also very interested in your mounting option/location and will greatly appreciate pictures. Also, major thanks for the warning re: using MONO input
  5. #5
    Join Date
    Aug 2010
    Location
    Utah
    Posts
    156
    Quote Originally Posted by Mr Droo View Post
    Yes, pictures would be Great! Thanks for taking the time to do the write up around this!
  6. #6
    Join Date
    Mar 2009
    Location
    Cleveland
    Posts
    622
    I took a few pics, but they were garbage. I took them in the garage and they turned out terrible. Here are two close ups of it while on the dragon at SB12 (Spring Bash 2012). I'll take a few more today... outside this time.
    Attached Images Attached Images
  7. #7
    Join Date
    Aug 2010
    Location
    Utah
    Posts
    156
    Quote Originally Posted by kromdom View Post
    I don't completely agree. They are supposed to be mounted in the center of the windshield under the rear view mirror which in theory has an unobstructed view through the back window as well. Not blocked by Bodies and metal.
  8. #8
    Join Date
    Aug 2010
    Location
    Utah
    Posts
    156
    Thanks for the pics Mr Droo! How are you attaching it to that bracket? What constant speed has it been tested at?
  9. #9
    wannabe HOON
    kromdom's Avatar
    Join Date
    Feb 2006
    Location
    SoCal
    Posts
    5,757
    Quote Originally Posted by nitro71455 View Post
    Have used my Escort on 5 different vehicles (2 trucks, 2 cars and 1 SUV) and position it in the dashboard. Front has an unobstructed view but the REAR is a different story: seats, rear window, rear hatch, passengers, etc. And NOT once has the detector failed to function. Went on a 2-day, 1800 trip last year with the detector inside a tank bag mounted on the gas tank with me in front of it. Again, the detector performed flawlessly.
    Above is my personal experience which is the basis for my earlier post. But hey, OK for us to agree to disagree
  10. #10
    Join Date
    Aug 2010
    Location
    Utah
    Posts
    156
    Good to know it works in the Tank Bag....... That my prompt me to put it on the little shelf in between the windshield and the Instrument Cluster.
  11. #11
    Join Date
    Mar 2009
    Location
    Cleveland
    Posts
    622
    I've had it mounted this way in excess of .... triple digits, we'll say. Here's a few I snapped.
  12. #12
    Join Date
    Aug 2010
    Location
    Utah
    Posts
    156
    Thanks all for the responses. After trying different methods and locations this is the one I've hardwired for and I'm sticking with. The Detector is sheltered from the elements, and is held into place with Velcro on the bottom and the suction cups on the top. It doesn't wiggle at all and is very happy here..
  13. #13
    Join Date
    Aug 2010
    Location
    Utah
    Posts
    156
    Dang the sideways picture........
  14. #14
    skydivr's Avatar
    Join Date
    Jun 2008
    Location
    Pleasant View, TN
    Posts
    13,272
    Not a flattering pic of me, but look down on the faring...
  15. #15
    Rookie Stealth_Busa's Avatar
    Join Date
    Dec 2002
    Location
    Texas
    Posts
    271
    Here is Mine...............
    84 Honda NightHawk S
    02 Hayabusa SE
  16. #16
    Join Date
    Mar 2009
    Location
    Cleveland
    Posts
    622
    Hey Nitro, are you using the aux input for a set of headphones/ear buds? Just a simple reminder to you (if you've forgotten) and anyone else, MONO INPUT ONLY! Bacon smells fantastic when fried, Escort RD's don't! You can use a mono to stereo adapter down the line if you need to, but a boostaroo, Amplirider, or similar will mix the stereo and mono outputs.
  17. #17
    Join Date
    Aug 2010
    Location
    Utah
    Posts
    156
    Naw.. not using the audio at all, only visual which is why i mounted the hard wire option at the top of my Double Bubble. Thanks for the heads up on and the rest of your input Mr Droo!
  18. #18
    wannabe HOON
    kromdom's Avatar
    Join Date
    Feb 2006
    Location
    SoCal
    Posts
    5,757
    nitro,
    In case you're still looking for mounting ideas, I finally got mine done. I "assembled" a kit using RAM pieces to mount my RD and GPS using the clutch reservour mounting bolts. I can take/post pictures later when I get home.
    P.S. I was all set to drill holes in my windscreen using the kit that STEALTH_BUSA above used but I swap screens around (ZG touring and DB) so ditched that option.
    * RAM Mount Medium Arm B-Socket RAM-B-201U
    * RAM Mount Extension Cradle Plate with Ball RMR-B-164-F
    * RAM Mount Motorcycle Handle Base with Double 1 inch Ball MODEL: RAM-B-309-6U
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
