You would bleed the sysem with DOT 4 brake fluid.. basically just like you would bleed you brakes. You should have a bleed screw on your clutch cover (or whatever it's called) down by the front sprocket
Yep, with a Mityvac and 8mm wrench what Tim is showing you in pics pretty simple & easy. With plastics off it's as easy as putting gas it the tank but can also be done fairly easy with plastics still on bike also. Easy Peasy
