riccoh
So, gauges look great, speedo healer website calculator (more of a reference starting point), it says to set up to -27.8%. Great start, but still left me with about the odometer at 3.5 miles off every 10 miles and the speedo at 13 miles off from actual speed.
After a 30 miles ride, set at 23.1% stoping every 10 miles (using the gps) I was able to get as close as 1.1 miles every ten on the odometer and within 1 mile on the speedo in the 30-110 range). I guess is as close as I can get,
question is.
It will be nice you to be able to set the SH based on speed, (helps keep the 5.o out of my hair, but my odo will suffer (as it will have less miles than actual). I rather have the odo off by 1.1 miles than the speedo off by 6 miles
1. Is everyone who has switch to the 220 MPH gauges really that much off?
2.How about with regards to the odometer?
how off is it based on actual distance/speed?
question is.
