Marble Mod !
NewbieOnBusa
So i was fed up from loud gunshot like noise that my exhaust was making so i finally did the famous marble mod. Also checked all the hoses and found one vaccum hose cracked up. Replaced that and wow... what a difference. Bike runs smoother and pulls harder!
1. Pop the seat and tank open
2. Right Side you will spot this hose connected to the Air Box! Pull the hose and remove the clamp !
3. Things you need.. Marble and Zip Tie.
4. Next you need to put something lubricating (oil, gel etc) on the marble to it easily slides in the vaccum hose. And push it in the hose for about 2 inches or so. I also recommend doing this when the bike engine is warm so that the rubber hose expands from heat thus preventing it from cracks!
5. After putting the marble in the hose, put a zip tie so it doesnt go down any further but do not over tighten the tie. Just secure the marble.
6. Thats it ! it should look like this
I hope this helps anyone out there. Total cost $8.93 just because i couldn't find any marbles and didn't have any ties!
ok.. I have BMC air filter and flashed ecu.. kept it cheap till i can afford a RCC turbo kit.. thanks for explaining it to me..
