mikejmd
I purchased a Harbor Freight tire changer with the motorcycle tire changer attachment.
I watched a few you tube videos of people changing tires with it. However, I did not always see the support arm (that bolts into the triangle frame) being used. Is its use necessary for function, safety or both? Do those on this board that use the HF motorcycle tire changer bother to install the support arm?
I also purchased a no-mar bar. Will I need to use tire irons along with the no-mar bar, or should the bar be enough by itself? I will be intstalling bt 016 front and rear (190/50)
Thanks, Mike.
Thanks, Mike.
